2020 Wiring Diagram (6 speaker system)
First post, but hopefully a useful one.  This was a PITA to get out of Ford.  I needed this info for installing a LOC behind the radio for the addition of an aftermarket sub.  They gave me the diagram, but I discovered there's a typo.  In the tech service document it shows the FRONT LEFT - as being Green/Brown, but that's incorrect. FRONT RIGHT - is Green/Brown.  The actual FRONT LEFT - is Gray/Brown.  Below are all the color combos as well as pin locations on the attaching wire harness.  It's a 24 pin connector with numbers on the back of connector.
2020
Ford Edge, 6 speaker
Left + (22) Blue
Left - (10) Gray/Brown
Right + (23) Yellow/Orange
Right - (11) Green/Brown
+12v Constant  (1) White/Brown
Ground (13) Black/Gray
Edited by DBBobbyT
typo
  • Thanks 1
  • 3 years later...
Front Audio Control Module (ACM) C240A via Instrument Panel main harness to Inline Connector C212 at front of Center Console...
2136998301_ACMConnectorC240AviaMainIPharnesstoInlineConnectorC212atCenterConsolefront-2022Edge.thumb.jpg.c5c302c8072374545ec1374bb762aaf0.jpg
Inline Connector C212 to Inline Connector C755 on LH B-Pillar...
1934918281_InlineConnectorC212toInlineConnectorC755onLHB-Pillar-2022Edge.thumb.jpg.22a5e5035512155e5c14dc72b2b15de6.jpg
Inline Connector C212 also serves Inline Connector C855 on RH B-Pillar...
505532055_AudioFrontControlModule(ACM)6-SpeakerWiring-InlineConnectorC855-RHB-Pillar-2022Edge.thumb.jpg.bb715e0a85a300c8b98f6cc4dea15ddb.jpg
ACM to 6-Speakers Wiring Diagram...
954711033_AudioFrontControlModule(ACM)6-SpeakerWiringDiagram-2022Edge.thumb.jpg.45dd91b3569fdb62f0e026b70e9b82d6.jpg
Document download links>
AUDIO CONTROL MODULE (ACM) - Connector C240A Details - 2022 Edge.pdf
Inline Connector C212 Circuit-Pin Details - 2022 Edge.pdf
Inline Connector C755 Circuit-Pin Details - 2022 Edge.pdf
Inline Connector C855 Circuit-Pin Details - 2022 Edge.pdf
REAR DOOR SPEAKER LH - Connector C702 Details - 2022 Edge.pdf
REAR DOOR SPEAKER RH - Connector C802 Details - 2022 Edge.pdf
Good luck!
