Seal between ptu and transmission
Toby Moore
8 hours ago, Toby Moore said:
I own a 2015 Ford Edge sport with
just over 50,000 miles. I’ve noticed a tiny amount of fluid seepage between the ptu and the transmission. Anyone else have this issue and is it a huge concern?
Try a forum search and you'll find that contrary to the manufacturers suggestion that the PTU is lubricated for life, it certainly does need oil changes.
You're at the mileage where you can expect that the oil has degraded to the point where the temperature will rise and start expelling oil.
If you haven't yet, get the oil changed and see if things improve, but if not plan for the seal replacement, and while you're at it get a drain plug fitted.
If your 60K mile power train warranty is still valid, get Ford to replace the seals.
