GregMag Posted May 1, 2020 Report Share Posted May 1, 2020 2017 Ford Edge Sport driver side rear turn signal blinker not working. Just replaced the tail light assembly (busted the old one). Front turn signal blinker works, inside dash panel blinker light going "fast" until you tap the breaks, slows the flashing down (due to increased resistance I believe). I think the "fast" flashing on the dash is due to lack of resistance. After replacing the rear driver's side tail light assembly, the turn signal blinker does not work, but brakes, flashers, etc. all do work. Any ideas? I don't see a fuse in the manual for turn signals. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 1, 2020 Report Share Posted May 1, 2020 Did you replace it with a new or used part? Are you sure you got the correct part? SEL & SE use a different part even though they look similar in daylight, the illuminate differently at night. 3 Quote Link to comment Share on other sites More sharing options...
GregMag Posted May 2, 2020 Author Report Share Posted May 2, 2020 Thanks for the reply omar302. I noticed while shopping for a new one that the Edge "Sport" had a different tail light than other SE & SEL models. I specifically ordered the one for the Sport, doubled checked when ordering but don't know if they sent me the right one or not. They look very similar on the outside for sure. I'll take it off and check the part number on the one rec'd. The part matching system on ebay says it is compatible with the following: This part is compatible with 1 vehicle(s) matching 2017 Ford Edge Sport Sport Utility 4-Door 2.7L 164Cu. In. V6 GAS DOHC Turbocharged. (my car model) Part & Fitment Details Item Description: fits 2015 2016 2017 2018 Ford Edge Drive LH Left side Tail lamp light Titanium/Sport Model Outer (on Body) Position: Left Drive side LH Manufacture Part Number: HT4Z13405B Interchange Number: FO2800244 Quote Link to comment Share on other sites More sharing options...
GregMag Posted May 2, 2020 Author Report Share Posted May 2, 2020 (edited) After checking other websites for the part for the Edge "Sport" the tail light assembly part number for the "Sport" has an "N" (FO2800244N), which the one above that says it fits does not. I'm wondering if ebay's part matching program is wrong in my case? It appears the correct part number is the one with the N at the end of the part number and the one without the N is a different part? Edited May 2, 2020 by GregMag posted without finishing the content editing Quote Link to comment Share on other sites More sharing options...
GregMag Posted May 2, 2020 Author Report Share Posted May 2, 2020 (edited) The part ordered on ebay: https://www.ebay.com/itm/303519242602?ul_noapp=true Edited May 2, 2020 by GregMag delete double post and edit Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 2, 2020 Report Share Posted May 2, 2020 4 hours ago, GregMag said: The part ordered on ebay: https://www.ebay.com/itm/303519242602?ul_noapp=true Condition: Brand New Aftermarket Replacement Part. Personal preference, but I would go OEM for this type of thing. Ford Parts sales sites indicate the part number you posted above has been superseded. https://parts.lakelandford.com/p/ford__/Tail-Light-Assembly/75138811/HT4Z13405G.html 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 2, 2020 Report Share Posted May 2, 2020 I agree with @1004ron that these parts are better OEM. Check how the parking light illuminates at the back, is it the surrounding trim that would continue the light bar illumination? If yes, then that is the correct part for the Sport/Titanium. Maybe you just got a defective part. Not sure if the connector is the same, maybe try to connect it on the other side just to check the light function. 2 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted May 2, 2020 Report Share Posted May 2, 2020 does it have a raised area on left side of tail? the cheaper trim lights have a raised area in the plastic to visibly distinguish from the more expensive models 2 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 2, 2020 Report Share Posted May 2, 2020 11 hours ago, GregMag said: Thanks for the reply omar302. I noticed while shopping for a new one that the Edge "Sport" had a different tail light than other SE & SEL models. I specifically ordered the one for the Sport, doubled checked when ordering but don't know if they sent me the right one or not. They look very similar on the outside for sure. I'll take it off and check the part number on the one rec'd. The part matching system on ebay says it is compatible with the following: This part is compatible with 1 vehicle(s) matching 2017 Ford Edge Sport Sport Utility 4-Door 2.7L 164Cu. In. V6 GAS DOHC Turbocharged. (my car model) Part & Fitment Details Item Description: fits 2015 2016 2017 2018 Ford Edge Drive LH Left side Tail lamp light Titanium/Sport Model Outer (on Body) Position: Left Drive side LH Manufacture Part Number: HT4Z13405B Interchange Number: FO2800244 The seller does that list when they create the item. They could say it fits a Dodge in the list if they wanted to. Always double check with OE Ford parts listings when getting something from Ebay. 2 Quote Link to comment Share on other sites More sharing options...
GregMag Posted May 3, 2020 Author Report Share Posted May 3, 2020 Thanks for all the help everyone; greatly appreciated. I had no idea there was so much variation in a tail light part for a Ford Edge Sport 3 years old. For anyone else looking to solve the same issue, OEM appears to be the best way to go. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 3, 2020 Report Share Posted May 3, 2020 1 hour ago, GregMag said: Thanks for all the help everyone; greatly appreciated. I had no idea there was so much variation in a tail light part for a Ford Edge Sport 3 years old. For anyone else looking to solve the same issue, OEM appears to be the best way to go. Another personal preference, I don't buy from an eBay seller that has a few as 6 reviews, been an eBay seller for a short time and return policies like this one. Quote Based in United States, excellence-autoparts has been an eBay member since Jan 22, 2020 Return Policy We are committed to providing the best customer satisfaction possible. We will gladly refund or replace any defective item and most non-defective items. However, we reserve the right to charge a restocking fee of up to 10% of the order. Within 30 days of receipt of your order, you may return products that: Are in their original packaging Have original manufacturer information Are not used, installed, or disassembled Are not damaged due to incorrect installation Do not have missing parts, hardware or instructions. Return shipping paid by: Buyer 2 Quote Link to comment Share on other sites More sharing options...
GregMag Posted May 8, 2020 Author Report Share Posted May 8, 2020 Update: no issues returning the item to this seller. They paid the return shipping and fully refunded the purchase given it wasn't the right part as advertised. Excellent seller based on my experience with the tail light purchase/return. 2 Quote Link to comment Share on other sites More sharing options...
