Donny Star Posted April 25, 2020 Report Share Posted April 25, 2020 Greetings----I have 2013 Edge Limited----I'd like to leave the key fob in the car when I go surfing, and then use my door 'keypad' code to unlock the door when I'm done----but when I go to leave the key fob in the car, the car recognizes the key is in the car and won't lock. Suggestions? Thanks so much. Quote Link to comment Share on other sites More sharing options...
handfiler Posted April 25, 2020 Report Share Posted April 25, 2020 This would be a good place to start: Faraday Pouch Quote Link to comment Share on other sites More sharing options...
Guest Tucker Posted April 25, 2020 Report Share Posted April 25, 2020 In order to successfully lock a fob inside the vehicle you have to use the keypad. Hold down on the 9-0 and 8-7 buttons for about two seconds. Use you keyless code as normal to unlock. Any other locking method will trigger the lockout protection feature if the vehicle detects any fobs left inside. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 25, 2020 Report Share Posted April 25, 2020 What he said ?. Only since you have a physical keypad (not touch), you don't have to hold the buttons, just press them simultaneously. Quote Link to comment Share on other sites More sharing options...
David Young Posted April 25, 2020 Report Share Posted April 25, 2020 Just did a test. I rolled the key fob in a sheet of aluminum foil. It will not detect the key. Cheap and simple Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted April 25, 2020 Report Share Posted April 25, 2020 (edited) 19 hours ago, Donny Star said: Greetings----I have 2013 Edge Limited----I'd like to leave the key fob in the car when I go surfing, and then use my door 'keypad' code to unlock the door when I'm done----but when I go to leave the key fob in the car, the car recognizes the key is in the car and won't lock. Suggestions? Thanks so much. Use the door keypad if you have it. Press the 7-8 and the 9-0 buttons simultaneously. The doors will lock with the fob inside. This may or may not work for a '13 but worth a try....It's also a good way to lock the doors and leave the engine running (run a quick errand or pick up the kids at grandma's and leave the AC or heat running). That trick is actually best done if you've set 'police mode' via FORScan so the transmission can't be pulled out of park without the key inside the Edge. Cheers! Edited April 25, 2020 by Gadgetjq 1 Quote Link to comment Share on other sites More sharing options...
Donny Star Posted April 26, 2020 Author Report Share Posted April 26, 2020 Thank you so much, I will try this and report back, thank you----hiding your keys under the bumper isn't the safest bet! Quote Link to comment Share on other sites More sharing options...
David Young Posted April 27, 2020 Report Share Posted April 27, 2020 I tried the 7-8 9-0 button locking with the key fob inside the Edge. It works on my 2014. Just use the door code to unlock the door. Quote Link to comment Share on other sites More sharing options...
TNEdgeOwner Posted April 30, 2020 Report Share Posted April 30, 2020 (edited) Hmmmm, I have a 13 SE and I lock my key inside all the time and use keypad to get back in........no 7-8 9-0 buttons, no nothing......just lock and walk! ?? Just noticed OP's car is Limited, mine probably works because I don't have pushbutton start?? Edited April 30, 2020 by TNEdgeOwner Quote Link to comment Share on other sites More sharing options...
akirby Posted April 30, 2020 Report Share Posted April 30, 2020 51 minutes ago, TNEdgeOwner said: Hmmmm, I have a 13 SE and I lock my key inside all the time and use keypad to get back in........no 7-8 9-0 buttons, no nothing......just lock and walk! ?? Just noticed OP's car is Limited, mine probably works because I don't have pushbutton start?? Exactly. It’s only an issue with the Intelligent Access fobs. Quote Link to comment Share on other sites More sharing options...
