Nascar99 Posted April 23, 2020 Report Share Posted April 23, 2020 Need Help... I've got a 2016 Edge Sport and while doing a thorough spring cleaning I ran the battery down such that it went into battery savings mode. After I started the vehicle I noticed that both Signature LED's no longer work. I have tried everything including; disconnecting the batt, a BMS reset, a reset of the BCM, and looking for a fuse issue (not sure which fuse it is, but didn't see any issues). Any insights and help would be appreciated!! Thanks. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 24, 2020 Report Share Posted April 24, 2020 (edited) The below is from the 2015 service manual. My guess is that something got disconnected from the BJB. Check BJB fuse 20. I think it is the same one that is labeled in the owner's manual as "Run/start lighting. Headlamp leveling switch." In the fuse box inside the engine compartment. Also attached is the diagnostics manual. Seems you need Pinpoint Test C. Signature Lamps Each of the signature lamp assemblies consist of multiple Light Emitting Diodes (LEDs) that receive fused voltage when the ignition is in ON or START. When the signature lamps receive fused voltage from the BJB, and the parking lamps are OFF, the signature lamps illuminate at full intensity. When the parking lamps are activated and the BCM sends a second voltage to the signature lamps to indicate the parking lamps are activated, the signature lamps operate at a reduced intensity. Parking, Rear and License Plate Lamps DT.pdf Edited April 24, 2020 by omar302 Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted April 25, 2020 Author Report Share Posted April 25, 2020 Wow thanks for the diagnostics manual info omar302!! I did check that fuse and it is fine. I'll take my time and sort through the info and try that test when I get a chance. I'll be able to report back in a couple of days. Cheers! Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted May 1, 2020 Author Report Share Posted May 1, 2020 Still no luck - Complete head scratcher! I had a cursory look at the BCM connections and pins, I'll have more time this weekend to do more thorough looking and testing. On a side note the vehicle has the LMS Tune and various FORscan adaptations. I rolled everything back to stock also having no change... Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 1, 2020 Report Share Posted May 1, 2020 (edited) Those lights have nothing to do with the BCM and are not programmable. They are powered by the junction (fuse) box under the hood. Edited May 1, 2020 by jmr061 Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted May 2, 2020 Author Report Share Posted May 2, 2020 Thanks! I did check the BJB and the associated fuse, but both are ok. Yes, I don't believe the Signature lights are programmable, but there seems to be a dimming circuit via the BCM. They are dim with the Park lights on. Getting close to pulling wires...Maybe I'm better off calling it a day and painting both Signature lights gloss back!! Lol. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 2, 2020 Report Share Posted May 2, 2020 15 hours ago, Nascar99 said: Thanks! I did check the BJB and the associated fuse, but both are ok. Yes, I don't believe the Signature lights are programmable, but there seems to be a dimming circuit via the BCM. They are dim with the Park lights on. Getting close to pulling wires...Maybe I'm better off calling it a day and painting both Signature lights gloss back!! Lol. They are wired into the parking lamp circuit for dimming and the splice for that is up front in the parking lamp circuit, not inside so if you parking lamps work the circuit is fine. 1 Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted May 3, 2020 Author Report Share Posted May 3, 2020 Ok, thanks! Got the multimeter out today and doing some more testing. Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted May 5, 2020 Author Report Share Posted May 5, 2020 Sooo, after initially messing around and chasing my tail with FORscan programing and the BCM (I thank my friend for this who is a big Audi guy), I found a broken wire. The break was located In the circuit between connector C140 and splice S187. See attached. Thanks guys for the help, happy to have them working again!!! Broken wire.pdf 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted May 5, 2020 Report Share Posted May 5, 2020 How did it get broken...was anything else damaged? Just curious if its a defect, poor harness placement, operator error? Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted May 6, 2020 Author Report Share Posted May 6, 2020 I have no idea. I'm the second owner of this vehicle, it has a clean history with no accidents or repairs. Also, I have never tampered with anything up front in that area. From my observation, it appeared that the wiring harness was original and had not been tampered with. There was a bit of water/corrosion in the area of the break, but unless the wire's insulation had a flaw, it should not have caused a break IMHO. Quote Link to comment Share on other sites More sharing options...
sshawn Posted August 8, 2024 Report Share Posted August 8, 2024 On 5/5/2020 at 2:49 PM, Nascar99 said: Sooo, after initially messing around and chasing my tail with FORscan programing and the BCM (I thank my friend for this who is a big Audi guy), I found a broken wire. The break was located In the circuit between connector C140 and splice S187. See attached. Thanks guys for the help, happy to have them working again!!! Broken wire.pdf Nice diagram, can you point me to where you got it? Quote Link to comment Share on other sites More sharing options...
Nascar99 Posted August 10, 2024 Author Report Share Posted August 10, 2024 I tried to find out the name of the online business I bought it from, but I can't remember and nowhere in the manual does it say a company name. It has about 14,000 pages of information, it has been very helpful, and I would buy another one for my next vehicle. It cost about $200 and like I said, it was purchased online, then simply downloaded once the payment was made. Sorry I couldn't provide the name! I'm kicking myself now. Lol Quote Link to comment Share on other sites More sharing options...
