Front Marker lights - how to disable with Forscan?
  • 1004ron changed the title to Front Marker lights - how to disable with Forscan?
If you mean the front one which is also the front turn signal bulb, you can do so in ForScan. I posted it previously in this thread.
10 hours ago, 2FAST4U said:
But…WHY?… :headscratch:
Claude.
Because it looks so much better ? I posted some night shots in that thread. But if the OP is from Europe and had an imported US Edge, he would probably want to do it to comply to some regulation about front marker light that should be white, which the signature lights would comply to I guess. Found similar questions in the ForScan forums.
