2020 Ford Edge - How to remove center console/Armrest compartment?
My mother somehow dropped her diamond earring and it managed to fall into the 12v outlet in the armrest compartment. I reached in to get it out but found out that there is a hole big enough just for the ear ring to fit and fall through!!! Does anybody know how I can remove all the trim and/or the center rotary shifter knob to get into the center to get her ear ring?
Any and all help would be greatly appreciated!
Hi Zach,
Take a look at this video through roughly the 4 minute mark (you won't need all the tools shown at the beginning, just a pry tool.  It's for the earlier Gen2 with shift lever but the concept is going to be the same.  Remove the two side pieces, pull up on the cup holder section and voila!  You're in.   Good luck!
55 minutes ago, zach4488 said:
What video? I don't see a link or address.
Oops, sorry been a long day here's the link but the video TXAggie sent you is probably better.  Once that center piece is removed you should be able to peer down into the area under the console box area.
Edited by Gadgetjq
  • 10 months later...
