2019 Edge SEL AWD - Trailer lights on, Edge is off.
Hope this is right place to put this thread.
2019 Edge SEL AWD with factory hitch and 4 pin connector.
I have noticed a few times while towing different trailers that the the lights on the trailer will randomly come on and stay on for awhile even with the Edge off and not being used. It has the keyless entry and start. I hooked up a trailer to go to the landfill the next day and later that night the trailer lights are on (clearance lights). Lights for the trailer have a light-up connector that tells you what lights are getting power etc and that will light up at the same time the clearance lights turn on.
Edge is off, no lights on the Edge. Doors are locked. I noticed this when the Edge was fairly new, month or so and under 4k kms. Now its 6 months old and 17k kms and the 4 pin terminal is badly corroded... it has been covered when not in use.
I have looked through the dash options and I cannot find any settings regarding trailers or lighting for them?
hmm. My first trailer was a small enclosed with clearance lights all around top and bottom. Second has just rear tail lights. Both trailers are incandescent bulbs.
I just got it back from dealer yesterday for a new torque converter. Will look through the paperwork to see if they even looked at it.
  • 1 year later...
  • 11 months later...
There was a SSM for this and I had it applied (fixed lights on when engine off).
SSM 49179 - 2015-2020 Edge, 2016-2018 MKX, 2019-2020 Nautilus - Parking Lamps Stay On And/Or Trailer Lights Flicker With Vehicle Turned Off
  • 4 weeks later...
SSM 50175 - 2015-2021 Edge, 2016-2018 MKX, 2019-2021 Nautilus - Parking Lamps Stay On And/Or Trailer Lights Flicker With Vehicle Turned Off
Some 2015-2021 Edge, 2016-2018 MKX, and 2019-2021 Nautilus vehicles may exhibit the parking lamps stay on and/or the trailer lights flicker with vehicle turned off when a trailer is connected to the vehicle. This may be due to the software in the trailer module (TRM). To correct the condition, reprogram the TRM with the latest software of the appropriate Ford diagnostic scan tool. Use causal part 19H332 and applicable labor times from Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
 2015 - 2021 CAR: DQ CD539N EDGE
 2016 - 2021 CAR: D9 U540N MKX
