jonolach Posted April 5, 2020 Report Share Posted April 5, 2020 Hey yall Got my 2007 edge sel plus over a month ago Just had the passenger side bearing done and the 2 front lower control arms. Everything seemed to be going good and then a few days after I can hear a clunking noise when turning at slower speeds . Left and right . I feel its unsafe but I know the mechanic said everything was good to go. Any idea what this could be I just spend 350 to get this replaced and fixed. I hate the clunking noise it bugs me cause I know its probally something bad He did mention to get an alignment after but said no rush as I was gonna swap tires in a few weeks. Any helps is good Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 5, 2020 Report Share Posted April 5, 2020 On 4/5/2020 at 11:16 PM, jonolach said: I can hear a clunking noise when turning at slower speeds Expand That sounds like the Constant Velocity joints are bad, and they're not too pricey to get them replaced at a drive-shaft shop. Look under the car at the drive-shafts and see if any of the rubber boots on the drive joints are leaking lubricant - these joints usually last long if the rubber boots stay in tact. Quote Link to comment Share on other sites More sharing options...
jonolach Posted April 6, 2020 Author Report Share Posted April 6, 2020 On 4/5/2020 at 11:26 PM, 1004ron said: That sounds like the Constant Velocity joints are bad, and they're not too pricey to get them replaced at a drive-shaft shop. Look under the car at the drive-shafts and see if any of the rubber boots on the drive joints are leaking lubricant - these joints usually last long if the rubber boots stay in tact. Expand Thanks for the quick reply I'll have a look in the morning Safe to drive still or should i use my 2nd vehicle? Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 6, 2020 Report Share Posted April 6, 2020 On 4/6/2020 at 12:14 AM, jonolach said: Safe to drive still or should i use my 2nd vehicle? Expand If its the drive joints, they've got to get really bad, and loud, before they become unsafe to drive. Quote Link to comment Share on other sites More sharing options...
jonolach Posted April 6, 2020 Author Report Share Posted April 6, 2020 Thanks so much I appreciate the help 1 Quote Link to comment Share on other sites More sharing options...
jonolach Posted April 13, 2020 Author Report Share Posted April 13, 2020 Had a look and cv joints look to be fine I'm leaning more over to a upper strut mount ... when driving slowly and turning wheel back and forth to the right then left I hear a twangy noise. Like a springy noise I'll get it diagnosed and see starting to hate this vehicle Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 14, 2020 Report Share Posted April 14, 2020 Good likelihood of the strut mounts being bad. Depending on mileage, you may want to replace struts AND strut mounts, and in pairs. Maybe even the springs. You can get assemblies from Summit Racing or put together your own from Rock Auto. Motorcraft mounts and springs, Motorcraft or KYB struts. Top choices. KYB rides firmer than stock, and is a perfect goto for those with the Plus, Limited, or Sport. Quote Link to comment Share on other sites More sharing options...
wahrsuul Posted June 23, 2020 Report Share Posted June 23, 2020 Please reply if you find the issue. My 2007 has had the mystery clunk for several years. I've replaced the struts and mounts, the sway bar bushings and end links. I've had two different mechanics look at it and they can't see anything that might be causing the issue. The ball joints seem tight as do the tie rods. I've been replacing parts as I get the funds to do it. It's the wife's vehicle so it doesn't get driven much and isn't a priority, but the clunk is still annoying. Quote Link to comment Share on other sites More sharing options...
