WTB: 2015 edge rear differential
Check
eBay would be a goo source. Also TascaParts is website I used a lot for OEM parts. Though are you sure the rear end is failing? I don't recall members with such issues.
Also, if you do replace it eventually, remember that you will need to update the rear axle code into the PCM. either through a dealer or perhaps ForScan.
Active Torque Coupling Configuration.pdf
