dtappeiner Posted September 5, 2008 Report Share Posted September 5, 2008 I wanted to try to get an estimate on my new Edge's gas mileage, so I let it run down to empty (even past the E) and then went to fill up, but it only took 16.5 gallons. This is fine because I then just divided the mileage by 16.5 gallons, but what the heck? Ho wwill I know when the car is actually empty (or close to it)? Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 5, 2008 Report Share Posted September 5, 2008 I wanted to try to get an estimate on my new Edge's gas mileage, so I let it run down to empty (even past the E) and then went to fill up, but it only took 16.5 gallons. This is fine because I then just divided the mileage by 16.5 gallons, but what the heck? Ho wwill I know when the car is actually empty (or close to it)? So, what kinda MPG did you get? I just checked my MPG for teh first time and I got a horrible 14.6 MPG! These are combo city/highway miles too! I know I am a leadfoot, but my co-worker is getting better mileage with her Suburban. Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 5, 2008 Report Share Posted September 5, 2008 I wanted to try to get an estimate on my new Edge's gas mileage, so I let it run down to empty (even past the E) and then went to fill up, but it only took 16.5 gallons. This is fine because I then just divided the mileage by 16.5 gallons, but what the heck? Ho wwill I know when the car is actually empty (or close to it)? I also saw similar results for the relationship between teh gauge and teh tank size. My gauge showed 3/4 and it only took 12 gallons to fill. These are supposed to be 19 gallon tanks, so there must be a 3 gallons (16%) buffer on the gauge. Quote Link to comment Share on other sites More sharing options...
dtappeiner Posted September 5, 2008 Author Report Share Posted September 5, 2008 I also saw similar results for the relationship between teh gauge and teh tank size. My gauge showed 3/4 and it only took 12 gallons to fill. These are supposed to be 19 gallon tanks, so there must be a 3 gallons (16%) buffer on the gauge. Yep, I am only getting around 15 mpg. Most of my driving is around town though and I drive pretty hard. I guess the only real benefit of this is that you are less likely to run out of gas and this will probably also protect the fuel pump, etc. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 5, 2008 Report Share Posted September 5, 2008 I wanted to try to get an estimate on my new Edge's gas mileage, so I let it run down to empty (even past the E) and then went to fill up, but it only took 16.5 gallons. This is fine because I then just divided the mileage by 16.5 gallons, but what the heck? Ho wwill I know when the car is actually empty (or close to it)? If you have the message center you can set it for Distance to Empty - that's a little more accurate than the analog fuel gauge. But the answer is if the needle is close to E then you need fuel - period. There is usually a built-in 1 or 2 gallon reserve but you don't want to use that unless absolutely necessary. In other words, don't make a habit of going past E. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 5, 2008 Report Share Posted September 5, 2008 on a similar note here.. I always just fill up when I opt to get gas. Never have taken my car near empty. My car always, like clock work, always reported like "343 Miles To Empty". every time this was the same. Well, recently I did take the car near empty. As close as I have ever gotten.. maybe like 15 miles the Info Center sadi... and upon fill up it jumped up to like "376 Mile To Empty". Pretty big jump. Not sure the, if any, correlation. But, interesting that all the other fill ups - dozens - at not even close to E and it reports same miles every single time and one time I go way down low to E it like resets the available miles seemingly. Like a recalibration? I am about to test this again just for fun as I am getting close to E and I am going to run it about same - right down to E - and see what it reports for "xxx Miles To Empty". Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted September 6, 2008 Report Share Posted September 6, 2008 Are you filling the tank with the engine running? I did that one time with my MKX & it wouldn't fill completely. When full, it will read around 415 miles to empty. When I left the engine running it was somewhere around 360 miles to empty. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 6, 2008 Report Share Posted September 6, 2008 me personally, I cannot recall the last time I ever left an engine running while filling up with gas. maybe last time I was in cold snowy conditions - but never in this car. Quote Link to comment Share on other sites More sharing options...
goatee Posted September 6, 2008 Report Share Posted September 6, 2008 Mine was made around the same time as Lex' Edge. If my gauge reads empty I can pump about 18.5 to 19 gallons into that 20 gallon tank. I was actually kinda surprised to see it take so much. I never noticed now many miles per gallon reads on the message center. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 6, 2008 Report Share Posted September 6, 2008 Mine was made around the same time as Lex' Edge. If my gauge reads empty I can pump about 18.5 to 19 gallons into that 20 gallon tank. I was actually kinda surprised to see it take so much. I never noticed now many miles per gallon reads on the message center. I would be curious what people leave their message center read out as normally? I see the only real message of value to me is the "XXX Miles To Empty" message and never switch off of that really. Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 6, 2008 Report Share Posted September 6, 2008 I would be curious what people leave their message center read out as normally? I see the only real message of value to me is the "XXX Miles To Empty" message and never switch off of that really. I don't have the message center on my Edge, but my wife does on her Taurus. She always leaves it on the xxx Miles to Empty. Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted September 7, 2008 Report Share Posted September 7, 2008 I would be curious what people leave their message center read out as normally? I see the only real message of value to me is the "XXX Miles To Empty" message and never switch off of that really. I leave it on miles to empty. Once in a while, I check to see the MPG. Currently shows 22.1. Highest ever is 22.3. Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 7, 2008 Report Share Posted September 7, 2008 I leave it on miles to empty. Once in a while, I check to see the MPG. Currently shows 22.1. Highest ever is 22.3. Has anyone even checked the message center calculated MPG against actual MPG? Quote Link to comment Share on other sites More sharing options...
goatee Posted September 7, 2008 Report Share Posted September 7, 2008 I leave mind on avg mpg. Only going to the mpg if the low fuel light goes on - then I hit the reset button and go back to the mpg screen. Its a personal choice thing. Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted September 8, 2008 Report Share Posted September 8, 2008 I think mine shows 37. Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 8, 2008 Report Share Posted September 8, 2008 I think mine shows 37. 37 MPG !!!!!!!!!!! ?????????? You must have a hybrid version that the rest of us don't know about! Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted September 8, 2008 Report Share Posted September 8, 2008 37 MPG !!!!!!!!!!! ?????????? You must have a hybrid version that the rest of us don't know about! No, there is another screen that I THINK says average mpg. That number doesn't seem to add up to me either. Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted September 8, 2008 Report Share Posted September 8, 2008 No, there is another screen that I THINK says average mpg. That number doesn't seem to add up to me either. OK, I read the owners manual. That screen shows average speed. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 8, 2008 Report Share Posted September 8, 2008 Has anyone even checked the message center calculated MPG against actual MPG? I know many Ford owners who have checked theirs on various vehicles and it's usually within 1/2 mpg, sometimes 1-2 mpg. Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 8, 2008 Report Share Posted September 8, 2008 OK, I read the owners manual. That screen shows average speed. LOL In that case it would look like I was getting 56 MPG. We are all entitled to a Homer moment. Doh. Quote Link to comment Share on other sites More sharing options...
Freeflyer Posted September 8, 2008 Report Share Posted September 8, 2008 Got my edge know for 2 month and i put already 3000km on it and I love it!! My message center is always set to the average consumption which I reset every time i refuel, and I calculate the exact value by hand. I got now everything from 12mpg (20l/100km) with purely city-leadfoot driving to 26 mpg (8.9l/100km) on the canadian highway (100 km/h)... Now I am looking for better brakes... anyone have an idea? Quote Link to comment Share on other sites More sharing options...
gradywhite Posted September 8, 2008 Report Share Posted September 8, 2008 Got my edge know for 2 month and i put already 3000km on it and I love it!! My message center is always set to the average consumption which I reset every time i refuel, and I calculate the exact value by hand. I got now everything from 12mpg (20l/100km) with purely city-leadfoot driving to 26 mpg (8.9l/100km) on the canadian highway (100 km/h)... Now I am looking for better brakes... anyone have an idea? Thanks for the feedback. Have you seen that teh message center calcs match your hand calcs. I As far as the brakes go, I believe there are otehrs posts that address that. I would suggest that you search those and maybe even create a new post of your own requesting info. Quote Link to comment Share on other sites More sharing options...
Freeflyer Posted September 8, 2008 Report Share Posted September 8, 2008 Thanks for the feedback. Have you seen that teh message center calcs match your hand calcs. I As far as the brakes go, I believe there are otehrs posts that address that. I would suggest that you search those and maybe even create a new post of your own requesting info. Yep... I think the message center is quite accurate. (0.2l/100km to low) But I keep doing the hand calcs. Thanks for the hint with the brakes... Quote Link to comment Share on other sites More sharing options...
jpeckinp Posted September 8, 2008 Report Share Posted September 8, 2008 Has anyone even checked the message center calculated MPG against actual MPG? I did on a trip from Chicago to Vegas this summer and it averaged about 1.5MPG off of a true calculation. The DIC would say 23.5 and actual would be 22. Quote Link to comment Share on other sites More sharing options...
