08 edge high headlights always on
08edgelimited22
My bright headlights will not go off . They have constant power to them all the time . I have checked all fuses in engine compartment and passenger . I replaced the mfu and that didn’t work . Unplugged the light where you turn off and on that didn’t work , unplugged the pcm lights still stayed on . You either have to leave unplugged or disconnect the fuse out of box for the high headlights . I’m not seeing a relay for the brights ! I’ve pulled all relays out 1 by 1 with brights plugged in and still they stay on . Please HELP ME ! I put a volt meter on the highs and they are reading 11 volts etc.... always getting power .
  • 6 months later...
