SDguy2020 Posted February 19, 2020 Report Share Posted February 19, 2020 Need some assistance on the auto control please ? I start my 2017 Edge SEL with the fob in the early morning. Auto control is set to 72 degrees. Once inside the vehicle I look at the control panel see the inside temp set at the 72 degrees and the outside temp is at 55 degrees. Why is my a/c light on? I am getting heat but do not understand why the a/c is on and stays on. See picture. Click to enlarge. Still under warranty for next 6 months. Thanks Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 19, 2020 Report Share Posted February 19, 2020 You can use your a/c with the heat on, it helps get rid of the moisture. With the settings you have selected, it automatically turns on the a/c to get the inside air temp to 72 degrees, whether the outside temp is 40 degrees or 90 degrees. If you're worried the having the heat on with the a/c will cause damage, you're not going to do any harm. It's perfectly normal. I do it all the time with my 2010 E-350 work truck & our 2016 SEL. 2 Quote Link to comment Share on other sites More sharing options...
akirby Posted February 19, 2020 Report Share Posted February 19, 2020 As stated above it dehumidifies the air which is then warmed to the correct temp. Running the ac keeps the seals from drying out and actually extends the life. It’s a good thing. 2 Quote Link to comment Share on other sites More sharing options...
SDguy2020 Posted February 19, 2020 Author Report Share Posted February 19, 2020 Hi, Thanks for the timely response. I feel much better about Auto Control function. My last new vehicle was your basic 2003 Ford Ranger and technology has changed a lot since then. My Edge and Ranger both run like champs. Appreciate the information. Good day ! Quote Link to comment Share on other sites More sharing options...
