Front License Plate Frame
CVCashmere
Several of us have drilled out the rivets holding the bracket and then plugged the holes .There are plugs that have matching paint(expensive) or you can just use black  plugs from Pep Boys ( budget ).
https://www.bumperplugs.com/index.php?route=product/category&path=1_11
I just used the black ones.
Edited by Xtra
Update:
Since I have to use a front plate and the factory bracket was already mounted on my ST, I bought a black metal frame to cover the top front of the bracket where you slip the plate under to hold it (you use 2 screws on the bottom).
Here it looks better as the bracket and cover frame blend together to hide the edges of the license plate.
I have enclosed the brand i bought from Advance Auto.
Thanks
CVCashmere
Scan_0014.pdf
