2013 Ford Edge Engine Stalling in idle speed and showing low engine oil pressure
Jins
Hi guys,
My 2013 ford edge engine stalling in idle speed and showing low engine oil pressure warning, the engine starts normally after turn off the key and restarts. My car has done 10600KM so far, this happened to me several times now. If the Aircondition is in the on state then the engine won't stop, also two or three times I felt an engine shivering during refueling and the engine stalled. There is a slight variation in the RPM in idle speed. Mechanic scanned the ECU but he couldn't identify any issues and said maybe some issues with the oil pump or electrical faults. I couldn't able to leave the car in the service center as they said it may take longer to identify and fix the problem.
Anyone experienced similar issues and know the real reason behind it? Please share.
  • 4 years later...
reviving an old post, do you remember how you were able to identify that this was the issue?
My 2011 Edge just started doing the same thing. Also getting a message about the fuel lid, not sure of the exact verbiage.  The stalling just started today while the fuel lid message is about a week old.
Another strange issue was that the breaks were hard to press down for a bit but eventually went back to normal.
2011 Ford Edge, 3.5L, AWD
145,000miles
145,000miles
99% chance that it's the purge valve.  I'd just go ahead and replace it cuz they're cheap and take about 5 minutes to replace.  I actually replaced mine in the Autozone parking lot:)  Toss your receipt in the glove compartment cuz I think Autozone is lifetime on these and I had mine replaced once.
  • 10 months later...
