14AWD3.5 Posted February 9, 2020 Report Share Posted February 9, 2020 Hi all, So my extended warranty is up March 30 and I thought I’d get this checked but wanted to know what you all thought. My 62K 2014 awd has been fine (3 tpu changes, 1 coolant, 1 tranny, 1 rdu, and my own p steering and brake fluid reservoir drain and fill) however for the last 10k or so miles I have been hearing (only at low speed as tires mask it) an rpm dependent whine, fairly quiet. I know it might be a pulley or bearing or trans but can’t tell. It doesn’t seem to make the noise except when in D and moving. When I rev it some in N or P I don’t hear it. I know that all fluid levels are ok. Any thoughts? Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted February 11, 2020 Author Report Share Posted February 11, 2020 Anyone? crickets... Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted March 14, 2020 Author Report Share Posted March 14, 2020 (edited) Hi again, I’m thinking its the use of the wrong ps fluid. I had used O'Reilley's generic “Ford approved” fluid, 1 qt worth. That drained and refilled the reservoir 3-4 times. Now 8K later I thought I’d see if using a motocraft Mercon LV ATF would improve anything. I performed the same pump out and refill, turning wheels lock to lock about 5 times each drain and fill, for a total of 4X, which was just over 1 qt. However, even reading the specifcations page in the manual theres no fluid capacity listed for the p steering. Kinda’ stumped. So anyone know how many qts are needed to fully flush out the system? Edited March 15, 2020 by 14AWD3.5 Typo Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted March 15, 2020 Author Report Share Posted March 15, 2020 (edited) I ended up calling Ford parts and they said it is a 2.4 pint capacity, so just over 1 qt. The parts guy said use Mercon 5 but LV would be ok, as it is a more recent fluid... Since I only flushed 1 qt, there will still be old fluid in the system, so I’d better flush another quart. Maybe then that will quiet it as its even noisier now (likely is air in the line). Next on my list of maintenance items to try and screw up is the trans fluid getting siphoned out through the dipstick. I’ve got 8 qts of Mercon LV to use, will try and siphon out, refill, drive, siphon out, refill, drive... maybe 2.5 times of doing that. Won’t change it all but should get it roughly 50% renewed. (10 qt capacity) Edited March 15, 2020 by 14AWD3.5 Typo Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted March 15, 2020 Author Report Share Posted March 15, 2020 Ok for the one person who’s reading this, the second full flush with another qt of Mercon LV has quieted the pump. Guess it didn't like the generic OReilleys ps fluid. 3 Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted June 2, 2020 Author Report Share Posted June 2, 2020 Noise/whine came right back within a day even with Mercon LV. Guess it still has air trapped in it. Tried lock-to-lock turns about 25 times to burp it out but still there. Not too loud but can be heard. Oh well, at least the fluid is much cleaner. Quote Link to comment Share on other sites More sharing options...
Olson_jr Posted June 29, 2020 Report Share Posted June 29, 2020 My 2013 has always has a slight PS pump wine. The dealer has told me that is is normal. Did a fluid change and it didn't change anything. Lately, I have been noticing a new wine along with PS. I believe it is transmission related. Time will tell. Quote Link to comment Share on other sites More sharing options...
sp9239 Posted August 30, 2020 Report Share Posted August 30, 2020 Hello! I have and 07 MKX with 139,000 miles and notice similar symptons on the engine vine/hawling while acelerating and moving card along the freeway. Also, I did a Power Steering Fluid replacement with new Mercon V after the old was was very dark/blackish. However, the problem still there. Since MKX share same engine as Edge I though I post this for any update on the issue. My next step was to consider replacing the TSS sensors as explained in below video on Youtube. sp9239 Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted June 29, 2021 Author Report Share Posted June 29, 2021 (edited) I changed PTU fluid (5th time in 105K) last week and the whine is gone. Could have been low from the previous Firestone change, don't know but the whine is gone. Nothing else was disturbed so I'm thinking that was it, a low amount of gear oil. Strange since there was no evidence of a leak. Now I'm unsure if Firestone filled it. I drove on their service fill for 30K without incident so perhaps it was simply low?. Edited June 29, 2021 by 14AWD3.5 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 19, 2021 Report Share Posted July 19, 2021 On 6/29/2021 at 4:01 PM, 14AWD3.5 said: Strange since there was no evidence of a leak. Now I'm unsure if Firestone filled it. I drove on their service fill for 30K without incident so perhaps it was simply low?. Could be the fluid got hot and starting congelling, (not leaking). Quote Link to comment Share on other sites More sharing options...
C.uptee Posted November 30, 2024 Report Share Posted November 30, 2024 I’m having similar clicking noises. I’ve noticed when I accelerate it faintly does it when I let off the gas it does it louder. After I’ve been driving for a while it goes away completely I can stop and go with no noises. If I park my car for a few mins and accelerate and then let off the gas again makes the same noise. I checked trans fluid topped it off still making the clicking. Nothing in reverse or turning Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 1, 2024 Report Share Posted December 1, 2024 I've read where serpentine belt can cause clicking when accelerating and go quiet when hot. But could be several things. Need a mechanic to look at it. Quote Link to comment Share on other sites More sharing options...
