2013 Edge SE Inside Lighting (Map lights)
So I’ve got a 2013 Edge SE, the inside lights come on when you open the doors, and turn off / fade out when closed.
But my issue is the front lights (map lights) when pressed Doesn’t light up.. quit working. The rear work. Both front only work when the door opens. Now here is the odd part... when you press it when the door is closed and open the door that light doesn’t come on. Once pressed then the light will come on for the internal lighting.
But when the door is closed and you press it, no light. Can anyone give any insight?
Edited by Rinytin
