samxander Posted February 4, 2020 Report Share Posted February 4, 2020 i have a 2013 ford edge se, whenever i turn on the AC or just put the fan, i can smell gaz. anybody experienced this before? what can be the cause? Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted February 6, 2020 Report Share Posted February 6, 2020 I'm assuming gasoline. Are you parking in a garage? Time to take a good look (and sniff) at the engine compartment. Evap system, fuel lines, etc. Fumes getting into the cowl area from someplace. Any check engine lights on, Gas cap. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 6, 2020 Report Share Posted February 6, 2020 Is it gas or propane smell? Is it under hard acceleration or under cruise / mild acceleration, as long as A/C is on? The exhaust flaps behind the bumper cover may be stuck open. The flex pipe in the exhaust may be cracked or broken. Propane smell usually happens on AWD vehicles when the PTU fluid leaks out. Quote Link to comment Share on other sites More sharing options...
