cleekoguy Posted January 19, 2020 Report Share Posted January 19, 2020 2016 Edge Titanium with 32000 miles. Ran it for 45 minutes at idle last night to update the Sync 3 with thumb drive. Shut it off and went to bed. This morning the battery was completely dead, no start, no lights, no dash, even the garage opener button didn't work. What could possibly cause this. Never any problems in the past. G. Quote Link to comment Share on other sites More sharing options...
Bfazona Posted January 19, 2020 Report Share Posted January 19, 2020 I had the same experience with mine and your battery was likely already on the way out. When they start to go bad, they do not hold a charge very well. Couple that with cold weather, and it sucks the charging power out of them quickly. If your battery was the original, then you were due for a battery, regardless of the low miles. Low mileage does nothing for battery life, as batteries are tied to physical time, usually lasting between 3-5 years. Quote Link to comment Share on other sites More sharing options...
cleekoguy Posted January 20, 2020 Author Report Share Posted January 20, 2020 Thanks B. I will look into the battery problem. I would hope that is not the problem and that the battery would last 5 years or so. I kept the battery charger on it overnight and so it started right up yesterday and seemed to have everything in the settings saved as normal. G. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 20, 2020 Report Share Posted January 20, 2020 1 hour ago, cleekoguy said: I will look into the battery problem. I would hope that is not the problem and that the battery would last 5 years or so. Batteries in modern vehicles rarely last more than 3-4 years. Quote Link to comment Share on other sites More sharing options...
JoeVic Posted January 20, 2020 Report Share Posted January 20, 2020 1 hour ago, cleekoguy said: Thanks B. I will look into the battery problem. I would hope that is not the problem and that the battery would last 5 years or so. I kept the battery charger on it overnight and so it started right up yesterday and seemed to have everything in the settings saved as normal. G. That's what I thought. The original battery on my 2015 SEL died a few weeks shy of 3 years. Just under the wire to get it covered by the warranty. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 20, 2020 Report Share Posted January 20, 2020 If you want to extend the life top off the fluid level once a year, get a Solar BA-7 type tester and a C-Tek charger/reconditioner and charge it once a month or so. Otherwise just plan to replace it every 3-4 years. Quote Link to comment Share on other sites More sharing options...
cleekoguy Posted January 21, 2020 Author Report Share Posted January 21, 2020 Okay, thanks everyone for the comments and suggestions. Here is the conclusion to my problem Battery. It was the original battery. Today the Dealer load tested the battery and found that it was too low on power to pass. Dealer installed and new battery for me. Crossing my fingers that this one will last 4 or 5 years. G. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted January 21, 2020 Report Share Posted January 21, 2020 I usually get a lot more life out of 65 series batteries then 59. My 2011 came with a 59 but was also designed to take a 65. Needless to say there's a big ole 65 under the hood these days. Quote Link to comment Share on other sites More sharing options...
