Dylan2012edge Posted January 17, 2020 Report Share Posted January 17, 2020 Hi my name is Dylan. I was wondering if anyone is having the same issue with there edge as I am. So it’s the 3.5 awd model and when the car is warm it randomly revs up and down. It will be at like 700-800 rpm and just randomly every 10-15 seconds rev up to like 1300 rpm and go back down. And I’m getting terrible fuel economy. I get like 9-10 mpg so something it obviously off. And yes I did check for a vacuum leak and found the pcv valve disconnected from the air box. So that helped with some other issues I was having but didn’t fix this current issue. I’m more concerned with the mpg right now. I’m filling up like 2 times a week. Someone pls let me know if u know a fix!! Quote Link to comment Share on other sites More sharing options...
Perblue Posted January 17, 2020 Report Share Posted January 17, 2020 Could be alot of things but start with the basics. How many miles and when were the spark plugs last done? 1 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 17, 2020 Report Share Posted January 17, 2020 Did I miss it, or was the model year/mileage stated? There are a few common problems we can think of, but they can vary by model year/generation. Typically the high rev means a component coming on (such as A/C compressor) OR an intermittent vacuum leak that forces the PCM to raise revs to stabilize the engine. But there can be many reasons, including worn out spark plugs as PerBlue mentioned. 1 Quote Link to comment Share on other sites More sharing options...
Dylan2012edge Posted January 17, 2020 Author Report Share Posted January 17, 2020 So I had spark plugs done about 10-15k miles ago. So I don’t think it’s the spark plugs unless I have some kind of bigger underlying problem and the plugs are fouled out. And also it’s a 2012 edge 3.5 awd Quote Link to comment Share on other sites More sharing options...
Dylan2012edge Posted January 17, 2020 Author Report Share Posted January 17, 2020 Also the car has 93k miles on it Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted February 9, 2020 Report Share Posted February 9, 2020 (edited) Well theres a couple other things you need to get checked at your trusty blue oval shop, like getting the coolant changed (internal water pump dont let that fail) and the PTU fluid on the awd. Don’t skip that one either. Both repairs are like $2400 and $1600 respectively. While you are in there have them run a diagnostic for the surging and mileage issues, cars are too complicated to properly internet diagnose. It does sound fuel related though, maybe. Course by now you should have already found out what it was... Edited February 9, 2020 by 14AWD3.5 Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted June 2, 2020 Report Share Posted June 2, 2020 Be nice if OP would respond with what it was, you never know if it would help someone else but... Quote Link to comment Share on other sites More sharing options...
