elsamahi Posted January 15, 2020 Report Share Posted January 15, 2020 Hi, My car battery is dead one week back, today I tried to open the door and jump start it with another car, but the door not opened by the key. I tried to you two keys the door not opening, the key not moving right or left. any advice on how to open the door? Thank you Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 15, 2020 Report Share Posted January 15, 2020 Are you sure the door lock was never changed before? Try spraying some WD40 inside the key hole and try again. Quote Link to comment Share on other sites More sharing options...
elsamahi Posted January 15, 2020 Author Report Share Posted January 15, 2020 thank you .. ill try it Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted January 15, 2020 Report Share Posted January 15, 2020 On 1/15/2020 at 1:06 PM, elsamahi said: I tried to you two keys the door not opening, the key not moving right or left. any advice on how to open the door? Expand Follow Omar's suggestion to use a lubricant (silicone works, graphite is best) in the key hole first. Another suggestion, if the key number was recorded in the owner's manual check to see if that's the key you still have. Maybe someone replaced your fob and key in the past? If that doesn't work you're probably going to have to call a locksmith. Other forum members might want to take this opportunity to try their physical key to be sure it works rather than wait for the battery to die and possibly lock you out. Quote Link to comment Share on other sites More sharing options...
