Bonzo84 Posted January 8, 2020 Report Share Posted January 8, 2020 Well, I was checking any Sync updates online for my new 2018 Edge sport. It said Version 3 was available which I figured I had so I downloaded it to USB and put in car. I didn't see any notice anything was happening, no notice of updating. So against my better jusdgement I pulled the USB out. Well I think big mistake, my screen just has a half of nav map and is locked, I can do anything. Is there anything I can do, even via Forscan, or is it only something dealer can revive? Please help! Thanks!!!!!! Quote Link to comment Share on other sites More sharing options...
2FAST4U Posted January 8, 2020 Report Share Posted January 8, 2020 Did you try turning everything off and restart from the beginning?… or… I know there is some kind of "rebooting" or reinitializing procedure of the Sync system that you could also try… If that doesn't work, then bring the car to your dealer. Good luck, Claude. Quote Link to comment Share on other sites More sharing options...
Ron Jeremy Posted January 9, 2020 Report Share Posted January 9, 2020 Turn the car off, open the driver door, let everything shut down, start the ignition again and it should clear. if that doesn’t do it, disconnect the battery and try that again. if it’s still locked up, than I’d take it to a dealer. Quote Link to comment Share on other sites More sharing options...
