ANC module location?
The ANC is done by the DACMC that is contained within the ANC. The ANC is the CD unit of the infotainment system in the dash.
DACMC ­ 2.7L Only
The DACMC ANC function only operates while the engine is running, and the luggage compartment lid and all doors are
closed.
The DACMC is a digital signal processor that consists of an internal analog/digital converter and tone generator.
For ANC, the DACMC uses engine rotation speed data, engine torque data, accelerator pedal position data, and ANC
microphone input signals to calculate the targeted frequency needed to cancel engine noise within the passenger
compartment. The DACMC ANC frequency signals are output by the ACM to the audio DSP module as fluctuating AC
voltage. The audio DSP module sends the signal to the LHF door speaker, RHF door speaker, and subwoofer speaker as
fluctuating AC voltage.
The DACMC is contained within the ACM.
The DACMC and ACM require separate PMI procedures when the ACM is replaced.
