2016 Edge Titanium AWD Posted January 3, 2020 Report Share Posted January 3, 2020 Is there a simple and easy way to get an M3U playlist that runs fine with WinAmp and Windows 10 to run on the Synch 3 radio? Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted January 3, 2020 Report Share Posted January 3, 2020 Maybe you've already tried all this but check page 384-386 of your owner's manual. Here's a copy/paste (sorry, the formatting came out a little wonky) Accessing Your USB Song Library 1. Plug the device into your vehicle's USB port. 2. Press the MEDIA button (next to the audio display) to select USB playback. Message Description and Action This menu allows you to select and play your media files by artist, album, genre, playlist or track. Browse USB If there are no media files to access, the display indicates there is no media. 384 Edge (CDQ) Canada/United States of America, enUSA, Edition date: 03/2016, Second Printing SYNC™ If there are media files, you have the following options: Display Description and Action Play all indexed media files from your device one at a time in numerical order.* Play all Press the OK button to select. The first track title appears in the display. Access your playlists (from formats like ASX, M3U, WPL, or MTP).* Playlists 1. Press the OK button to select. 2. Scroll to select the desired playlist, and then press the OK button. Songs Search for and play a specific indexed track.* 1. Press the OK button to select. 2. Scroll to select the desired track, and then press the OK button. Sort all indexed media files by artist. The system then lists and plays all artists and tracks alphabetically.* Artists 1. Press the OK button to select. 2. Scroll to select the desired artist, and then press the OK button. Albums Sort all indexed media files by album.* 1. Press the OK button to select. 2. Scroll to select the desired album, and then press the OK button. Genres Sort all indexed media files by genre (category) type.* 1. Press the OK button to select. 2. Scroll to select the desired genre, and then press the OK button. Browse all supported media files on your media player connected to the USB port. You can only view media files that are compatible with SYNC. (Other files are not visible.) Browse USB 1. Press the OK button to select. 385 Edge (CDQ) Canada/United States of America, enUSA, Edition date: 03/2016, Second Printing SYNC™ Display Description and Action 2. Scroll to browse indexed media files on the device, and then press the OK button. Resets the USB index. After the new indexing is complete, you can choose what to play from the USB song library. Reset USB *You can use the buttons at the bottom of the audio display to jump to a certain alphabetical category quickly. You can also use the letters on the audio system's numeric keypad to jump in the list. 1 Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted January 4, 2020 Author Report Share Posted January 4, 2020 Boy sure is a lot of button pushing and OK'ing to get it to play, but I'll give it a whirl. Do I Have to do this each time insert the USB stick, or any other usb stick? Thanks. ? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 4, 2020 Report Share Posted January 4, 2020 40 minutes ago, 2016 Edge Titanium AWD said: Boy sure is a lot of button pushing and OK'ing to get it to play, but I'll give it a whirl. Do I Have to do this each time insert the USB stick, or any other usb stick? Thanks. ? Press the voice button. “Play playlist xyz.” couldn’t be simpler. 1 Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted January 4, 2020 Author Report Share Posted January 4, 2020 Now that, I will try ... Thanks Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted January 6, 2020 Author Report Share Posted January 6, 2020 Didn't quite work ... will find and play complete folders of music. I know the file label, but for some reason the assistant can't 'see' it. Assistant resorted to asking me to search a list of playlists, but couldn't find the one on the USB ... Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2020 Report Share Posted January 6, 2020 Well first you have to create the playlist file. Did you do that? 1 Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted January 7, 2020 Author Report Share Posted January 7, 2020 Yes - As I already said, I know the file label for the playlist - it's called 'Edge 2019.M3U8' It was created using WinAmp 5.66 on my laptop, as are all the playlists I use with our PC LAN here at home. There is 16.6 Gb of music on the stick, all stored in 'root' of the USB, some in artist folders, some as single tracks. Playlist selects tracks from folders and the general list of single tracks. The USB works fine in any PC, and even my son's Sync 2 - 2016 fusion - but not in this blessed Edge ... What the Edge does is maddening, - it plays all the singles and then switches to each individual folder ... Quote Link to comment Share on other sites More sharing options...
