Power steering issues. Hard to turn
Chigozie
What year Edge?  Is the fluid full?  Looks clean & healthy?  Then I suggest you try replacing it completely / flushing with Valvoline MaxLife Full Synthetic ATF, which is mercon V compatible.  Hope it is available where you are.
Is it more effort turning in one direction vs another?  Does the effort level go away with higher RPMs turning lock to lock while parked and idling?
it's a 2007 edge. the fluid level is not full. I will have to check my oil dealer if he has valvoline Maxlife.
It is hard on both right and left
