JoeCho Posted December 30, 2019 Report Share Posted December 30, 2019 Hello All, I have a 2011 Ford Edge and the climate control is not working at all via the touch screen. The control panel below my touch screen works, so I can turn the climate control on from there but the buttons within the climate control section of the touch screen do not work at all. So I cannot change what vents the air is coming out of and my heated seats will not turn on. The other odd thing is when I touch the screen the animation showing the button depressing happens, so I feel like the input is being recieved but no output is happening. Everything else on my screen works completely fine, steering wheel controls, I can blue tooth my phone, listen to music, make/accept calls. I have FORscan and went ahead and performed a self test on the following modules: APIM - PASS FCIM - PASS IPC - PASS HVAC - PASS I also performed module resets on: APIM - Success with no errors FCIM - Success with no errors IPC - Success with no errors HVAC - Success with no errors Body Control Module - Success with no errors I purchased a dealer service manual but wanted to post this problem here, I did try to search this issue but came up dry. Please let me know your thoughts or other trouble shooting steps that I may have missed. Thanks, Joe Quote Link to comment Share on other sites More sharing options...
slm42434 Posted November 6, 2024 Report Share Posted November 6, 2024 I'm having the same exact issue also have forscan. Need info can't find anything anywhere. Quote Link to comment Share on other sites More sharing options...
