2012 / Headlights and Tail lights Stoped Working
If you are using auto headlights,  The next time it happens turn the lights on manually.  Both the headlights and tail lights at the same time could point to BCM, Headlight Switch, Light sensor on the dash.
Switch tells the BCM to turn on or of the lights.  Sensor tells the BCM to turn on or off the lights if the switch is in the auto setting.
