bjonesva5 Posted December 26, 2019 Report Share Posted December 26, 2019 Got a 2011 Ford Edge SE , just recently no matter if I turn the heat knob to full cold I still get heat as if it were on the highest setting. Everything esse works fine, blower, can set defrost, vent floor settings no problem, just can't turn the heat down. Any suggestions? Thanks. Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 26, 2019 Report Share Posted December 26, 2019 It is probably the blend door actuator. Try resetting it by disconnecting the battery for 5-10 minutes or disconnecting the connector. If it doesn't work then it probably needs replacement. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 29, 2019 Report Share Posted December 29, 2019 yeah probably could use a recalibration, but IDK if the procedure for MyFord is the same as MyFordTouch. 1 Quote Link to comment Share on other sites More sharing options...
bjonesva5 Posted December 29, 2019 Author Report Share Posted December 29, 2019 Tried disconnecting the battery, no change. I think it controller is toast, will look at replacing it. Thanks all for the suggestions. Quote Link to comment Share on other sites More sharing options...
