rcaljr Posted August 22, 2008 Report Share Posted August 22, 2008 I am about to install a double-din head unit with DVD. Where is the wire to the parking brake located and where is the best place to splice in to it to connect the parking break lead from my head unit? Quote Link to comment Share on other sites More sharing options...
dehydorn Posted February 7, 2009 Report Share Posted February 7, 2009 I too could use a lil help on this, I just installed a Pioneer AVIC-F700BT and everytime I go over 15 i get a warning stating my parking brake wire is improperly installed.... its fairly annoying Quote Link to comment Share on other sites More sharing options...
dehydorn Posted February 7, 2009 Report Share Posted February 7, 2009 well I found it, its a little bit of a pain to get to. If you remove the trim panel directly below the steering wheel you can get at it a little better. Its a little switch that at the very top of the parking brake, I used the crimp on type of splicer. I connected mine to the blue wire coming off the sensor and it works fine. If you need let me know and I'll try to get you a pic tomorrow Quote Link to comment Share on other sites More sharing options...
