Rizsin23 Posted December 9, 2019 Report Share Posted December 9, 2019 (edited) Just curious if anyone can tell me where a good place to ground HIDs/accessories. There is an extension off the negative cable, is that the best place or is there somewhere better? Thank you! 2014 edge sel btw Edited December 9, 2019 by Rizsin23 adding info Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted December 10, 2019 Report Share Posted December 10, 2019 The negative cable or any direct cable from it is an excellent place for a ground but any metal panel on the vehicle will work just as well. Sometimes an extra wire run to that ground just isn't worth the trouble. I see you live in the Northeast so I'd suggest if you create your own ground (generally using a self tapping screw) you add a little paint to any new hole you make to avoid rust. 1 Quote Link to comment Share on other sites More sharing options...
Rizsin23 Posted December 10, 2019 Author Report Share Posted December 10, 2019 Thank you. I am going to get a grounding block and ground all accessories to that as I've been having battery problems. Quote Link to comment Share on other sites More sharing options...
