Smitty Posted December 6, 2019 Report Share Posted December 6, 2019 Have a 2012 3.5 that at times is hard to start. Before I go into detail though, what do you call the feature where you can turn the key, release it and it will continue to start? 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 6, 2019 Report Share Posted December 6, 2019 I believe it is the computer assisted cranking system. Quote Link to comment Share on other sites More sharing options...
Smitty Posted December 6, 2019 Author Report Share Posted December 6, 2019 17 minutes ago, omar302 said: I believe it is the computer assisted cranking system. Should there any difference in starting the motor using the CACS or turning and holding the key until the motor starts? I have always used the CACS and lately the motor acts like it is flooding or missing when starting. Once it starts everything runs fine. It seems to start fine when I turn and hold the key until the motor starts. Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 7, 2019 Report Share Posted December 7, 2019 Sorry, I don't know. But I'm sure someone will sure be able to answer your question. Quote Link to comment Share on other sites More sharing options...
Bigzoie Posted January 14, 2020 Report Share Posted January 14, 2020 On 12/6/2019 at 4:11 PM, Smitty said: Should there any difference in starting the motor using the CACS or turning and holding the key until the motor starts? I have always used the CACS and lately the motor acts like it is flooding or missing when starting. Once it starts everything runs fine. It seems to start fine when I turn and hold the key until the motor starts. I have similar if not the same issue, I try to turn on the vehicle and it just cranks for about 5 to 10 seconds then will start. I've replaced the spark plugs and EVAP sensor, but not sure what else could be wrong. I read that there is no serviceable fuel filter, so maybe it's the fuel pump? Quote Link to comment Share on other sites More sharing options...
Bigzoie Posted January 14, 2020 Report Share Posted January 14, 2020 I have similar if not the same issue, I try to turn on the vehicle and it just cranks for about 5 to 10 seconds then will start. I've replaced the spark plugs and EVAP sensor, but not sure what else could be wrong. I read that there is no serviceable fuel filter, so maybe it's the fuel pump? Quote Edit Quote Link to comment Share on other sites More sharing options...
Smitty Posted January 14, 2020 Author Report Share Posted January 14, 2020 Decided to check out the owners manual...I know, shame on me... Starting the engine 1. Turn the key to 3 (on) without turning the key to 4 (start) 2. Turn the key to 4 (start), then release the key as soon as the engine begins cranking. Your vehicle has a computer assisted cranking system that assists in starting the engine. After releasing the key from 4 (start) position, the engine may continue cranking for up to 10 seconds or until vehicle starts. So, according to the manual cranking up to 10 seconds is acceptable? As I mentioned before, mine seems to start ok if I hold the key in the 4 (start) position until it starts. It is when I release the key, as in #2 above and let the CACS do the work that it acts up. I would not think it is the fuel pump...vehicle runs ok once started. Maybe all of the fuel drains back into the tank and have to wait until it is pump back up to the engine? Quote Link to comment Share on other sites More sharing options...
