2015 Rear Axle Gear Oil
MLK2015
I changed the PTU and rear axle lube last week at 18,000 miles and used Red Line 75W-140 synthetic lube in both.  Will the 75W-140 cause any harm in the rear axle? I don't tow and and the AWD has only engaged maybe 3 times in the last 4 years. Should I go back to 80W-90 gear lube to be safe?
75W-140 is for your PTU. Redline offers 75W-90 for your differential.  75W-90 is a suitable alternative for 80W-90.
https://www.redlineoil.com/75w90-gl-5-gear-oil
