wlepse Posted November 22, 2019 Report Share Posted November 22, 2019 So for the last couple of months my wife's 2011 SEL Edge would seemingly pull timing but never threw a code. Originally I thought it might have something to do with the tone ring that needed replacement. Well after that was fixed it still happened but never threw any codes until about 2 weeks ago when I got a P0303-C. The CEL flashed for about 10 seconds then was gone. I cleared the codes and it finally came back indicating the same cylinder. So while I replaced the plugs about 50k ago with stick platinum plugs I plan on swapping them all out. I also picked up a coil pack to replace the #3 since it is likely on its way out. But I can't seem to find confirmation of which cylinder is which. One source said count from left to right on back bank. The other says to start in same spot but #2 is in front bank. Can someone please confirm which is correct? Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 23, 2019 Author Report Share Posted November 23, 2019 In case someone else is searching I am going with the #3 cylinder being in the back bank by the driver. I think the confusion comes in between the difference of cylinder number and firing order. Cylinder numbers are: firewall 1 2 3 4 5 6 But firing order is: firewall 1 3 5 2 4 6 I am going to assume the P0303 references the cylinder number not firing order. I hope this is correct. Below are some of the resources I used to come to this conclusion. https://www.explorerforum.com/forums/index.php?threads/2011-explorer-xlt-3-5l-v6-tivct-engine-misfire-p0201-p0301-p0316.451787/ https://www.manualslib.com/manual/745073/Ford-Transit-2015.html?page=268 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted November 24, 2019 Report Share Posted November 24, 2019 Not sure how much you're going to spend on 1 new COP but this Motorcraft kit comes with all 6 of them for $180.00. I know the COPs in this kit are the right ones for our 2011 3.5s. $180.00 is a pretty good deal for 6 of them and it's nice to install 3 new ones in the back while you have the upper intake off. 1 Quote Link to comment Share on other sites More sharing options...
