Can Forscan enable showing the active gear?
Jombi
35 minutes ago, Jombi said:
And I’ll quickly add “when in normal D mode, not Sport or Paddle mode”.   I just want to know what gear I’m in, I want to see when it’s skipping a gear, etc, but it seems it only shows the current gear# when you use the paddles.
Thanks,
Jim
Question asked here - near bottom of page:
12 hours ago, omar302 said:
If you're planning to get a tune, I remember someone saying Torrie from Unleashed was able to do it with his tunes. LMS tunes does not.
After running through every tuner expect Livernois i can give you some good advice.
If you are staying stock (or simple drop in filter): Unleashed and Livernois are great
If slightly modified:  BCB
if you want to go Full bolt ons: ZFG
This comes from 2 years of tuning on this platform and modification.
I'm getting too old and busy to do much mods--I'd love to open up the intake and exhaust, but for now it's drop-in filter and the Livernois tune.  Using Dragy, my stock 0-60 was 5.95.  Using the LMS 91 octane tune (with 93 gas) I got a 5.45.  I haven't tried the LMS 93 octane tunewith the Dragy yet, but I expect it to be 5.2-ish.
--Jim
--Jim
There isnt much in terms of intake bud, we do have down pipes tho.
best of luck my firend
