2013 SEL Driver's headlight inner lens cloudy ??
Our 2013 SEL driver's headlight bulb lights up fine, but the image seems to have a blob or something in the central part of the image.   The passenger side headlight displays fine....
Almost seems like the inside of the lens needs to be cleaned or replaced entirely....
Anybody have any suggestions or similar scenario ?
Thanks....
Sammydad1   new member, not a noob
Hi,
Decided to go hands-on tonite and opened up the rear cover behind the headlight bulb....
Apparently the bulb had managed to loosen itself in the housing so the bulb was sorta dangling inside the headlight assembly leading to the weird light pattern on the garage wall....   I was able to get it re-locked in place and the pattern now matches the passenger side....  Hopefully it stays locked in place....
SD1
