shumax Posted November 18, 2019 Report Share Posted November 18, 2019 I had the PTU fluid changed on my 2016 Sport, with 28,000 miles. Firestone charged me $90, including the fluid. I sent it out to Blackstone to have it looked over. The tech told me there was some sludge on the drain plug, but no shavings. Said it ran fluid, but was thick. Said changing it was the right move. Replaced with the OEM fluid. Interested to see what Blackstone has to say about it's condition... Shumax 3 Quote Link to comment Share on other sites More sharing options...
shumax Posted November 19, 2019 Author Report Share Posted November 19, 2019 (edited) Results. Edited November 19, 2019 by shumax 3 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 15, 2020 Report Share Posted July 15, 2020 (edited) interesting observation; i did my oil, ATF and PTU fluids about a month ago at ~45k miles. I fully expected the PTU fluid to be black and sludgy like it was on my 2011 Fusion Sport AWD at 59,000, but it came out Very Clean. unbelievably so. My guess is that the clutching system in the RDU that engages the power transfer to the rear diff on demand only, also significantly reduces the load on the PTU (and thus the fluid) except when said clutch is engaged. This is encouraging since they got a very bad rep in my book by calling the PTU on my 2011 Fusion Sport AWD a "lifetime fill" yet the fluid that came out when i did mine (around 65k) was more sludge than fluid.. That and the internal water pump that required dropping the drivetrain out to replace.. but that's another story for another time anyway, thought this might be interesting to others, it was to me Edited March 26, 2022 by Cerberus Clarity Quote Link to comment Share on other sites More sharing options...
THE_BOLT Posted July 15, 2020 Report Share Posted July 15, 2020 I am curious! I had the dealership replace all drivetrain fluids at 36000 miles when I had it in for warranty work. Now I'm almost at 76000 and going to change them at my buddys shop myself...except the trans fluid I will let him do that since I have no clue how to operate that machine. This time I'm planning on running redline oils in the PTU & RDU. The trans will stay motocraft. You have me curious about how my oil analysis will turn out. Quote Link to comment Share on other sites More sharing options...
t0lkman Posted August 31, 2020 Report Share Posted August 31, 2020 on what milage is it recommended to replace the PTU fluids? Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 31, 2020 Report Share Posted August 31, 2020 On 8/31/2020 at 6:39 AM, t0lkman said: on what milage is it recommended to replace the PTU fluids? Expand Browse the forum threads on this and I believe you'll find the personal preference ranges from every 30K miles to every 50K miles. I do it myself at around 30K miles. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 31, 2020 Report Share Posted August 31, 2020 Although things may have changed with Gen 2.5 / the 2019 MY, there are no clutches in the PTU. There ARE clutches in the RDU, but it is a sealed system, and separate from the gears, which is where we add RDU fluid. So, for all practical purposes, for 2007-2018, the PTU/RDU have no clutches to maintenance. 30K for the PTU, 60K for the RDU (or every other PTU fluid change) - assuming normal driving conditions, or let's say 2 yrs/4 yrs, assuming the average miles/year people drive nowadays. https://www.bts.gov/statistical-products/surveys/national-household-travel-survey-daily-travel-quick-facts Quote Link to comment Share on other sites More sharing options...
t0lkman Posted August 31, 2020 Report Share Posted August 31, 2020 Thanks for the replies! Obviously, I wouldn't be able to change the PTU fluids myself. Do you think I can stop by the local Ford dealership and ask to perform the PTU fluids change? How much this procedure might cost? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 31, 2020 Report Share Posted August 31, 2020 gen 2+, yes. prev gens, try your luck at the Ford dealer, talk to the trans tech direcly. OR go directly to a Lincoln dealer where they are much more likely to do it for prev gens. Standalone L dealer if you can find one, or a combo where you talk to a Linclon service advisor. Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 31, 2020 Report Share Posted August 31, 2020 (edited) On 8/31/2020 at 9:44 PM, t0lkman said: Thanks for the replies! Obviously, I wouldn't be able to change the PTU fluids myself. Do you think I can stop by the local Ford dealership and ask to perform the PTU fluids change? How much this procedure might cost? Expand Not so obvious, ......many here change the PTU fluid themselves. Depends on Year/Model. Please consider adding Location and Year/Model to your profile signature - https://www.fordedgeforum.com/settings/signature/ Edited August 31, 2020 by 1004ron Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 1, 2020 Report Share Posted September 1, 2020 Ford's Owners Manual supplement for the Middle East specifies 20K miles for normal driving & 9K miles for severe duty. 2 Quote Link to comment Share on other sites More sharing options...
t0lkman Posted September 1, 2020 Report Share Posted September 1, 2020 @omar so why in the US there is no recommendation for PTU lube? PS. 2016 MY is gen2 or gen3? Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 2, 2020 Report Share Posted September 2, 2020 On 9/1/2020 at 10:00 PM, t0lkman said: @omar so why in the US there is no recommendation for PTU lube? PS. 2016 MY is gen2 or gen3? Expand You need to ask Ford that question. My guess is because of the much warmer weather here and that folks here assume crossovers are SUVs so they would still take them on sand dunes. Gen1: 2007-2010 Gen1.5: 2011-2014 Gen2: 2015-2018 Gen2.5: 2019-2021 1.5 & 2.5 are referred to as 0.5 updates because they are refreshed models with the same chassis & many shared components. 1 Quote Link to comment Share on other sites More sharing options...
