Bill Walton Posted November 13, 2019 Report Share Posted November 13, 2019 Over the course of Edge model years has the same "size" rim changed from year to year ? I have a 2013 with 245 60/R18 tires 18" OEM rims, I am looking at a set same tire/rim size, but there from a 2016 Edge is there differences (different offset, hub size etc) or would these be a no fuss change ? Thanks Bill Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted November 13, 2019 Report Share Posted November 13, 2019 I believe the bolt pattern is different between the Gen1 and Gen2 Edges. Wheels from one can't be used on the other. 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted November 13, 2019 Report Share Posted November 13, 2019 Your bolt pattern is 5x114. The 2015+ edge bolt pattern is 5x108. Unfortunately they will not fit the previous generation. Quote Link to comment Share on other sites More sharing options...
2FAST4U Posted November 13, 2019 Report Share Posted November 13, 2019 (edited) All Edge wheels from 2006-2014 have a 114.3 mm. bolt pattern and are interchangeable between those years and from 2015 to 2020 have a 108 mm. bolt pattern are also interchangeable between those years... but … ---> the wheels will NOT interchange between the first generation (2006-2014) and the second generation (2015-2020). hope this helps... Claude. Edited November 13, 2019 by 2FAST4U 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 14, 2019 Report Share Posted November 14, 2019 9 hours ago, 2FAST4U said: All Edge wheels from 2006-2014 have a 114.3 mm. bolt pattern and are interchangeable between those years Although the 2011-2014 years have the same bolt pattern as 2007-2010 years, they have a different hub size. 2007-2010 uses 70.6mm 2011-2014 uses 63.4mm Not really direct bolt on. Quote Link to comment Share on other sites More sharing options...
Bill Walton Posted November 16, 2019 Author Report Share Posted November 16, 2019 Thanks to everyone who replied, you saved me a 60 mile drive and $1200 bucks All the Best Bill Quote Link to comment Share on other sites More sharing options...
