SOLVED - Factory mode warning while programming remotes
Hi
I have a 2013 Edge SEL, I installed the factory VSS, long range antenna and the aerial antenna.
I enabled the BCM and IPC in Forscan, all looks fine.
The VSS module programs just fine.
The problem is that when I try to program the remotes I get a yellow warning as "Factory Mode, Contact Dealer".
Did anyone knows what config  do I need?
Edited by laupetre
