2008 Ford Edge Battery drain test leads to Subwoofer amp/(audiophile radio) fuse
So I have this edge for quite a while and had a draw on my battery where if I drove it ever day I wouldn't have a problem. But I didn't drive it for two days the battery would be completely dead. I always had a jumper box with me or if I knew i would not be driving for a couple days I would disconnect the battery.... Which I know isn't a great idea. So I finally got tired of this and did the ole battery drain test by pulling fuses. My draw went way down when I pulled fuse #38 on the drives inside fuse box. Which is the Subwoofer amp/audiophile fuse. I'm just checking around to see if anyone else has had a similar problem. I simply pulled the fuse and not the car has sat for three days and still starts and my battery is not dead. Any help would be greatly appreciated
