Paulreed Posted October 17, 2019 Report Share Posted October 17, 2019 Hi! I have a Ford Edge 2019. I desperately need an aux input for my car. It appears not to be included with the car. What are my options??? thanks in advance! Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted October 18, 2019 Report Share Posted October 18, 2019 you'll need an adapter: https://www.amazon.ca/UGREEN-Adapter-External-Stereo-Headset/dp/B06XP5R449/ref=pd_bxgy_147_img_3/134-9934936-2876707?_encoding=UTF8&pd_rd_i=B06XP5R449&pd_rd_r=aed271e4-db60-476d-b9e2-ab62de1ad2a4&pd_rd_w=hpGyw&pd_rd_wg=93ysd&pf_rd_p=48fa4823-918c-4290-bdea-b573af9832e2&pf_rd_r=2RZE30JDW8D1X8JTJ68C&psc=1&refRID=2RZE30JDW8D1X8JTJ68C https://www.amazon.ca/TROND-External-Adapter-Integrated-Microphone/dp/B07L56C28R/ref=sr_1_3?gclid=CjwKCAjwxaXtBRBbEiwAPqPxcFyvuefeLKkZGS06m7zKYcPiz2qDatlYv40Qw3d2xPtzdF3oxCcbshoCJpAQAvD_BwE&hvadid=220844030587&hvdev=c&hvlocphy=9000791&hvnetw=g&hvpos=1o1&hvqmt=e&hvrand=1274572989873804924&hvtargid=kwd-316357140363&hydadcr=4651_9337947&keywords=usb+to+aux+female&qid=1571385118&sr=8-3 1 Quote Link to comment Share on other sites More sharing options...
Paulreed Posted October 18, 2019 Author Report Share Posted October 18, 2019 9 hours ago, ONEDGE16 said: you'll need an adapter: Thank you!!!! Quote Link to comment Share on other sites More sharing options...
Paulreed Posted October 20, 2019 Author Report Share Posted October 20, 2019 I'm missing something. Plug my phone into USB and it come up through CarPlay. Where do I make an 1/8 inch device play through when I hook it up through one of these adapters. Under entertainment sources I only have, (AM, FM, Sirius, CD, and bluetooth). What am I missing? Quote Link to comment Share on other sites More sharing options...
akirby Posted October 20, 2019 Report Share Posted October 20, 2019 Those adapters will work with sync 3. what exactly are you trying to connect? There may be other options. Here is a comprehensive discussion on options from the f150 forum. https://www.f150forum.com/f118/no-longer-have-3-5mm-line-now-what-do-i-do-350965/index10/ Quote Link to comment Share on other sites More sharing options...
Paulreed Posted October 20, 2019 Author Report Share Posted October 20, 2019 I'm trying to use an app on my phone called Amplitude. It has a dongle that is attached that has a 1/8 inch line out so I can play the sounds through the car system. I can listen with headphone on the dongle or attached a speaker that take an 1/8 inch like a Beats pill but would prefer to use the car system. I have a Ford Edge 2019 but don't know what version of Sync I have. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 20, 2019 Report Share Posted October 20, 2019 Ah I see now. So you want to play your guitar using the car stereo as the amplifier. Doesn’t that make it pretty hard to steer? A Bluetooth adapter is probably the best solution but the delay might be a problem. Quote Link to comment Share on other sites More sharing options...
