mamerc Posted October 13, 2019 Report Share Posted October 13, 2019 (edited) Daughter has a 2015 SEL, travels 20 miles to work and thankfully trouble started a block from home. Car started to shake very bad at the stop sign. no warning lights and no history. putting the car in park, everything is back to normal. I'm not talking "vibration" here. I'm talking this motor wants out on the car shaking! Check all mounts and removed the driverside upper, checked and it was like new. Trans fluid is correct, if this was a flywheel or TC issue, wouldnt it shake on idle in Park? I find nothing online with this problem. No lights, no codes. Ill update with vid when I can......Update, I will get a better video when I go to her house today IMG951221.3gp Edited October 14, 2019 by mamerc Quote Link to comment Share on other sites More sharing options...
Special_K Posted November 21, 2019 Report Share Posted November 21, 2019 On 10/13/2019 at 2:06 PM, mamerc said: Daughter has a 2015 SEL, travels 20 miles to work and thankfully trouble started a block from home. Car started to shake very bad at the stop sign. no warning lights and no history. putting the car in park, everything is back to normal. I'm not talking "vibration" here. I'm talking this motor wants out on the car shaking! Check all mounts and removed the driverside upper, checked and it was like new. Trans fluid is correct, if this was a flywheel or TC issue, wouldnt it shake on idle in Park? I find nothing online with this problem. No lights, no codes. Ill update with vid when I can......Update, I will get a better video when I go to her house today would On 10/13/2019 at 2:06 PM, mamerc said: IMG951221.3gp would love to help you but the video wont load. upload to youtube and post the link Quote Link to comment Share on other sites More sharing options...
