samsnew2this Posted September 26, 2019 Report Share Posted September 26, 2019 Has anyone started exploring changing the Edge drive system to something like the X5, Porshe or Alfa rear-drive for fun front drive if needed? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 28, 2019 Report Share Posted September 28, 2019 It's my understanding that the front drive is full time (mechanically) and there is a controller at the rear that determines when the back axle is connected or not. This would require a total rework of the the transaxle, PTU and read end to make it work. And, you wouldnt really gain anything, imo. The car was designed and balanced for front wheel drive. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 28, 2019 Report Share Posted September 28, 2019 The problem is the PTU and other systems are not built to send that much torque to the rear wheels for sustained periods. Just won’t work. Go buy an Explorer ST if you want RWD and high performance. Quote Link to comment Share on other sites More sharing options...
Waldo Posted September 30, 2019 Report Share Posted September 30, 2019 I don't even know where you would start with this kind of idea. You'd have to come up with an entirely new clutch system to disconnect the front axle. And then the rear axle is only sized for max 50% of the engine torque, so you'd basically have to shut down half of the cylinders in the engine. I don't see how that would be much fun. Quote Link to comment Share on other sites More sharing options...
