Gadgetjq Posted September 24, 2019 Report Share Posted September 24, 2019 (edited) I know, this has been posted before but thought I'd add a few pics along with a 'how-to'. This might be the simplest mod you can do to your Edge with the possible exception of swapping out lug nuts. I started with an aftermarket puddle light from iJDMToy ( https://amzn.to/2mmHnvc )primarily because I've used their products before and they've never let me down. If you look around you can probably find something similar for about half the price that may or may not be waterproof and may or may not be error free and might or might not last for years. Like my daddy once said "I'm too poor to buy cheap tools." Removal of the OEM puddle light is simplicity itself. Look under your mirror and you'll see a slot where you can insert a small flat blade screwdriver. Push toward the light and pull down. The light will simply hinge down so you can pull it out along with wiring. Pull the connector off of the OEM light (you might have to use that little screwdriver to pry it off). If your replacement comes with wiring already attached I'd recommend sliding a small piece of shrink tube over the connector (see pic). There's no use taking a chance metal will ever meet metal inside the mirror housing and take out an important fuse. After connecting your new puddle light open a door to be certain it works. Now you can shrink the tubing if you've used it. Put the new light in the mirror the reverse of the way you took the old one out (except you don't need the screwdriver). Repeat on the other side. Done! Below are photos showing a comparison of the OEM (incandescent) light and new LED, a shot of the new light dangling just to show the shrink tubing, a photo of it installed in the mirror housing and the result with no other light on in the garage. Compare that to what you have now. The final photo I shamelessly swiped from the iJDMToy website so those who prefer pics to text instructions can see how it's done. Cheers! Edited September 24, 2019 by Gadgetjq Added photo 4 Quote Link to comment Share on other sites More sharing options...
soUNTOUCHABLE Posted September 24, 2019 Report Share Posted September 24, 2019 Excellent! Will be changing mine out for the blue led set soon. Matches my body color! Quote Link to comment Share on other sites More sharing options...
BlueSteel Posted September 25, 2019 Report Share Posted September 25, 2019 9 hours ago, soUNTOUCHABLE said: Excellent! Will be changing mine out for the blue led set soon. Matches my body color! When you get the blue ones installed, upload a picture. My Edge is blue as well and I'd like to see how that turns out. 1 Quote Link to comment Share on other sites More sharing options...
txaggie Posted September 25, 2019 Report Share Posted September 25, 2019 has anyone tried/had luck with the ones that project the Ford logo on the ground? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 28, 2019 Report Share Posted September 28, 2019 I bought the ones with the Lincoln logo. In a word, crap. Swapped them out for a set of regular high-intensity LEDs. (Too dim, and these were the ones before the adjustable positioning ones so the logo was never lined up with the side of the car.) Also, I'd rethink going with blue. The human eye focuses blue differently than all other colors and has fewer blue receptors. The LEDs, no matter how bright they start off will appear dim or weak. (Don't over pay as you may not like the effect.) 1 Quote Link to comment Share on other sites More sharing options...
soUNTOUCHABLE Posted September 30, 2019 Report Share Posted September 30, 2019 On 9/28/2019 at 3:09 PM, enigma-2 said: Also, I'd rethink going with blue. The human eye focuses blue differently than all other colors and has fewer blue receptors. The LEDs, no matter how bright they start off will appear dim or weak. (Don't over pay as you may not like the effect.) Good advice, I'll def think on it. The seller has a picture of the blue puddle lights on a car and they seem pretty bright there, but there's always the chance that the pics are faked/edited in some way. Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted September 30, 2019 Author Report Share Posted September 30, 2019 21 hours ago, soUNTOUCHABLE said: The seller has a picture of the blue puddle lights on a car and they seem pretty bright there, but there's always the chance that the pics are faked/edited in some way. Based on the photos I'd guess you're hoping to purchase via Amazon. That company has an excellent return process if the item isn't what you expected. Bottom line, order with confidence you can return the lights (free) if they don't appear in the real world as they do in the pictures. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted October 8, 2019 Report Share Posted October 8, 2019 That's another project I have in the pipeline. I need to hit up Dan for a new set of puddle lamps for mine. Quote Link to comment Share on other sites More sharing options...
