Puddle Lights quit working
Smokey1757
Suggestion:  Puddle lights are simple to remove from the mirror.  Pull one out and test it with a direct connection to a power source (car battery, power supply, 9v battery).  It's possible both of your lights have simply burned out and a direct test is a good way to find out.
Replacements are inexpensive with LEDs as low as $10 on eBay.
Cheers!
In looking at the 2009 service manual (I think we can assume that the 07 is the same), the power is supplied through fune #10 (in the smart junction box) and then directly to both puddle lamps.
Assuming that you have not been messing with the wiring, it's either the fuse (try a different one known to be good) or the smart junction box (try a reset by disconnecting the battery for a few minutes).
