Lchampion Posted September 15, 2019 Report Share Posted September 15, 2019 Turn signal quit blinking. Changed the bulb twice and still not working. What is the next thing I should check? Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted September 15, 2019 Report Share Posted September 15, 2019 Questions that need answering before anyone can make a suggestion: Is the bulb lighting just not blinking or is it not coming on at all? Is the passenger side rear working properly or not blinking? Is the left side working properly? If the right rear is working correctly (or hyper flashing) it indicates bad bulb or possibly a bad socket/connection on the right front. Quote Link to comment Share on other sites More sharing options...
Lchampion Posted September 17, 2019 Author Report Share Posted September 17, 2019 Thank you so much for your response. Right front does not come on at all. Right rear is flashing faster than normal. Left side is working properly. Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted September 17, 2019 Report Share Posted September 17, 2019 2 hours ago, Lchampion said: Right front does not come on at all. Right rear is flashing faster than normal. Left side is working properly. Ok, something is making the Edge believe that right front bulb is out (which it is) thus the hyper flash. I know you said you'd changed the right bulb twice so that's probably not the cause. It wouldn't hurt to check the bulb again but test it with a power source (9V battery works) or test for resistance with a mutimeter or swap it with the left side bulb. Take a close look at the connectors at the bulb and at the headlight housing. Is something dirty or burned? A spritz with some contact cleaner wouldn't hurt. If none of the above is the cause you're going to be looking for a broken wire which is very unlikely. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 28, 2019 Report Share Posted September 28, 2019 My 09 does this every once in a while. Hyperflash. On time I get it, another I don't. Think its in the SJB. (Everytime I get hyperflash, I can correct it by turning off the turn signal and then turn it back on again. Happens once every 3-4 months or so) Quote Link to comment Share on other sites More sharing options...
