FordNut74 Posted September 13, 2019 Report Share Posted September 13, 2019 I just bought this 08 Edge and every once in awhile the trans will shift so hard it feels like someone rear ended you, there is no increase in RPM's or any kind of warning. the fluid is super clean and i put some "Lucas Trans No Slip" in and yesterday it happened again which means it will be awhile until happens again more than likely. Please help!! 2008 Edge 3.5L AWD Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 13, 2019 Report Share Posted September 13, 2019 (edited) Welcome! How much mileage on your Edge? Makes me suspect the solenoid body. It can be checked without any disassembly required. If the electrical values are near the limits of allowable specs, replace it along with the solenoid body filter. A simpler item could be the torque mount/dogbone. easy to check, a little harder to replace on AWD, but 2 hrs shop labor or DIY if you are handy. Edited September 13, 2019 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 25, 2019 Report Share Posted October 25, 2019 On 9/12/2019 at 10:34 PM, FordNut74 said: I just bought this 08 Edge and every once in awhile the trans will shift so hard it feels like someone rear ended you, there is no increase in RPM's or any kind of warning. the fluid is super clean and i put some "Lucas Trans No Slip" in and yesterday it happened again which means it will be awhile until happens again more than likely. Please help!! 2008 Edge 3.5L AWD See the notice at the top of this forum section - you may get a better response if you post in the appropriate section. Quote DO NOT use this forum for Ford Edge discussion. Quote Link to comment Share on other sites More sharing options...
