bubbadewsky Posted September 8, 2019 Report Share Posted September 8, 2019 (edited) You can connect a long transparent rubber hose to any vac. line that goes directly to the intake manifold (brake booster, PCV line) if you run the end of the line into the PTU or RDU fill plug you can suck out the fluid by starting the engine thus applying vacuum to the line....Be careful as not to suck out too much at one time as oil will not compress in the engine cylinders. If you go slow all that will enter the intake manifod is oil mist If your home made line is long enough it may empty the PTU before any oil reaches the manifold (in this case no microscopic metal fragments will enter the manifold) Edited September 8, 2019 by bubbadewsky Link to comment Share on other sites More sharing options...
1004ron Posted September 8, 2019 Report Share Posted September 8, 2019 12 minutes ago, bubbadewsky said: You can connect a long transparent rubber hose to any vac. line that goes directly to the intake manifold (brake booster, PCV line) if you run the end of the line into the PTU or RDU fill plug you can suck out the fluid by starting the engine thus applying vacuum to the line....Be careful as not to suck out too much at one time as oil will not compress in the engine cylinders. If you go slow all that will enter the intake manifod is oil mist If your home made line is long enough it may empty the PTU before any oil reaches the manifold (in this case no microscopic metal fragments will enter the manifold) I would strongly advise against attempting what's suggested here. @bubbadewsky have you tried this? An oil extractor can be used, but it doesn't work as well as the drain plug. Link to comment Share on other sites More sharing options...
bubbadewsky Posted September 8, 2019 Author Report Share Posted September 8, 2019 (edited) If you do not have a vac pump this will work with minimal expense.....why do you think this is a bad idea I already drained my PTU with 20 ft hose connected to manifold not a drop of oil reached engine ...sucked out approx. 14 oz ofcourse it's hard to get exact measurement since some oil remains in the hose When you drill a drain plug hole there is a chance of stripping the threads. If you compare an older PTU with the new drain plug style you will see extra reinforced metal around the plug Edited September 8, 2019 by bubbadewsky Link to comment Share on other sites More sharing options...
1004ron Posted September 8, 2019 Report Share Posted September 8, 2019 (edited) 11 minutes ago, bubbadewsky said: If you compare an older PTU with the new drain plug style you will see extra reinforced metal around the plug My PTU came with a drain, and it does not have extra reinforced metal around the plug. Where did you get this information from? Edited September 8, 2019 by 1004ron Link to comment Share on other sites More sharing options...
bubbadewsky Posted September 8, 2019 Author Report Share Posted September 8, 2019 8 minutes ago, 1004ron said: My PTU came with a drain, and it does not have extra reinforced metal around the plug. Where did you get this information from? If you do not have a vac pump this will work with minimal expense.....why do you think this is a bad idea I already drained my PTU with 20 ft hose connected to manifold not a drop of oil reached engine ...sucked out approx. 14 oz Link to comment Share on other sites More sharing options...
bubbadewsky Posted September 8, 2019 Author Report Share Posted September 8, 2019 Seen a pic of a new style PTU somewhere and the metal around the drain plug has a thick reinfored area Link to comment Share on other sites More sharing options...
1004ron Posted September 8, 2019 Report Share Posted September 8, 2019 21 minutes ago, bubbadewsky said: If you compare an older PTU with the new drain plug style you will see extra reinforced metal around the plug Try again......... My PTU came with a drain, and it does not have extra reinforced metal around the plug. Where did you get this information from? Link to comment Share on other sites More sharing options...
1004ron Posted September 8, 2019 Report Share Posted September 8, 2019 Just now, bubbadewsky said: Seen a pic of a new style PTU somewhere and the metal around the drain plug has a thick reinfored area Well I have a model that came with a drain plug and there is no such thing. Post the pic, lets all have a look. Link to comment Share on other sites More sharing options...
1004ron Posted September 8, 2019 Report Share Posted September 8, 2019 (edited) Anyway, you've creacted enough PTU threads, ignoring the long standing existing ones - for anyone else visiting here, I suggest that you go here: On 3/6/2016 at 11:29 PM, omar302 said: Just yesterday @threeputtpar posted here his guide. Edited September 8, 2019 by 1004ron Link to comment Share on other sites More sharing options...
onyxbfly Posted September 8, 2019 Report Share Posted September 8, 2019 9 hours ago, 1004ron said: Anyway, you've creacted enough PTU threads, ignoring the long standing existing ones - for anyone else visiting here, I suggest that you go here: Contributing to charity is very noblesse oblige of you.....feeding the trolls not so much! 2 Link to comment Share on other sites More sharing options...
bubbadewsky Posted September 10, 2019 Author Report Share Posted September 10, 2019 On 9/7/2019 at 9:51 PM, 1004ron said: My PTU came with a drain, and it does not have extra reinforced metal around the plug. Where did you get this information from? 2015 ford edge ptu drain plug with reinforced metal Link to comment Share on other sites More sharing options...
bubbadewsky Posted September 10, 2019 Author Report Share Posted September 10, 2019 On 9/7/2019 at 10:02 PM, 1004ron said: Well I have a model that came with a drain plug and there is no such thing. Post the pic, lets all have a look. Link to comment Share on other sites More sharing options...
1004ron Posted September 10, 2019 Report Share Posted September 10, 2019 2 minutes ago, bubbadewsky said: 2015 ford edge ptu drain plug with reinforced metal LOL Link to comment Share on other sites More sharing options...
1004ron Posted September 10, 2019 Report Share Posted September 10, 2019 1 minute ago, bubbadewsky said: 3 minutes ago, bubbadewsky said: 2015 ford edge ptu drain plug with reinforced metal Just now, 1004ron said: LOL LOL, LOL Link to comment Share on other sites More sharing options...
bubbadewsky Posted September 10, 2019 Author Report Share Posted September 10, 2019 Just now, 1004ron said: LOL, LOL are you a trouble maker or just afool Link to comment Share on other sites More sharing options...
1004ron Posted September 10, 2019 Report Share Posted September 10, 2019 (edited) On 9/8/2019 at 7:47 AM, onyxbfly said: Contributing to charity is very noblesse oblige of you.....feeding the trolls not so much! 28 minutes ago, bubbadewsky said: are you a trouble maker or just afool Here's a tip for you - https://www.brainyquote.com/quotes/mark_twain_103535 Edited September 10, 2019 by 1004ron 1 Link to comment Share on other sites More sharing options...
1004ron Posted September 10, 2019 Report Share Posted September 10, 2019 (edited) . Edited September 10, 2019 by 1004ron Link to comment Share on other sites More sharing options...
onyxbfly Posted September 10, 2019 Report Share Posted September 10, 2019 53 minutes ago, bubbadewsky said: What part of that area is reinforced? Reinforced compared to what? The 2015 AWD sport is the first Edge to have a drain plug on the PTU... Link to comment Share on other sites More sharing options...
handfiler Posted September 11, 2019 Report Share Posted September 11, 2019 2 hours ago, 1004ron said: Here's a tip for you - https://www.brainyquote.com/quotes/mark_twain_103535 Advice we should all follow. 1 Link to comment Share on other sites More sharing options...
akirby Posted September 11, 2019 Report Share Posted September 11, 2019 I think we've taken this one far enough. 1 Link to comment Share on other sites More sharing options...
