Oil Leak 2015 2.0l Ecoboost Edge
Tod
I have a oil leak and can't figure out the cause of it. Replaced the oil plug but still leaking. I read that the ecoboost 2015 has an issue with oil pressure sensor and leaks through the threat.
Have you had this issue and do you know where the sensor is located.
Thanks in advance
