2015 Edge fuse for third stop light location
Hello guys,
My third stop light stopped working and before replacing it, I would like to check if the problem is just the fuse. However, I am unable to find information showing me the fuse location for the stop lights. Would someone be able to help?
PS I am talking about the stop light located on the rear spoiler.
Thanks in advance
Fuse 54 in the under hood fuse box is designated for the brake light switch.  Check your owner's manual or the pictogram under the fuse box lid for the location.  If your center light is out and other brake lights work the fuse isn't the problem, (though it's easy to check).
It could be the light fixture but it's rare or an entire strip of leds to fail.  More likely it's a connection to it that's causing the issue.
