Removed Sirius/XM From Main Audio Display
Gadgetjq
My 3 month free trial of Sirius audio has run out.  I won't be signing up so cut some clutter on the main audio screen by removing it using FORScan:
APIM  7D0-01-01   *xxx  xxxx  xxxx
Decrement existing value where the asterisk is by 2;  if you have an "A" make it "8", if you have "2" make it "0"
Curiously, while this removes the service from the main screen, Sirius is still showing on the small right side audio screen.
  • 1 year later...
  • 9 months later...
 I don't remember where I found this table but was probably on a Fusion forum (http://2gfusions.net/showthread.php?tid=4573) or GoogleDoc. I have removed Sirius from the right cluster. I don't remember and haven't used Forscan in a long time (so my key is gone).
In my notes, I have
720-05-01
D838
0100
003E
but see from these notes that the XX3X controls Climate. I sort of remember trying lots of codes and must not have stored the actual change.
Dual Screen Cluster - Right Screen Modifications:
301
720-05-01 (2013+ MY)
XXXX xxxx xxxx
Note: Ignore bits marked with "x"
302
(IPC)
D8B8 (Default w/Navigation)
303
D8A8 (Default w/o Navigation)
304
1xxx (Removes AM/FM and CD from Entertainment Source List)
305
9xxx (Removes CD from Entertainment Source List)
306
xxx0 (Removes Phone Menu and Corresponding Alerts from Right Cluster Screen)
Note: Phone/Text Alerts still come up on 8" Sync2/3 Screen
307
xx3x (Removes Climate Control Menu from Right Cluster Screen) w/Nav
